Old May 20, 2022 | 02:24 PM
pizzaguy
Default Re: Don't start, don't lock unlock door, fun run without key
Originally Posted by giaiu79
problem almost solved.
broken fuel pump relay.
fans is ok.
there remains only the problem of the doors that do not lock or unlock with the remote control
If you have been struggling with electrical issues, it is quite common to see the sync between the key fob and SKREEM get lost.
To re-sync the fob to the SKREEM, do this:
STANDARD PROCEDURE - TRANSMITTER PROGRAMMING
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
