Re: ABS, BAS/ESP, Emergency Brake, Brake Pad light, Spoiler deploys on start
grossmj
So I am having a major problem on my 04' Crossfire that is getting worse with time. It has been happening for about a month now, but this week took it to another level. When I am trying and start my car I will put my key in the ignition and turn it to the run position, all the warning lights come on as usual, but when I try turning it over, the car will sometimes do absolutely nothing mechanical. I turn the car off, take the key out, put it back in, and try starting it. It will usually start the car right up after doing that, but sometimes I might have to repeat the cycle (like this morning when I had to repeat the cycle 7 times). The NEXT problem is when the car starts. As soon as my car starts, my spoiler will automatically deploy along with the light on the spoiler switch flashing. I then have to turn my car off and turn it back on so that the light on the switch stops flashing allowing me to put the spoiler back down. Also when I start my car, sometimes my ABS, BAS/ESP, Emergency Brake Light, and Wore Brake Pads Light will all come on at the same time. I again have to turn my car off and start it to make the lights disappear. Usually I have to do this cycle only one time, but yesterday right after church I had to repeat this cycle 4 times before the lights went away. Last week on Tuesday I was driving it on a 45mp road and all four lights came on; this was the first time this happened while driving. It did nothing to my car EXCEPT automatically shifted me down one gear and WOULD NOT shift back up. I looked at the gear screen next to the clock in my gauge cluster and the screen was totally black (no 1, 2, 3, 4, or D). Before I could pull my car over to check it, all the lights disappeared and my transmission shifted back to normal as if nothing ever happened. This same case also happened yesterday as I was leaving the church parking lot. I have noticed the spoiler will ALWAYS automatically deploy when the four lights come on, but will also automatically deploy WITHOUT the four lights. PLEASE HELP ME!!! I DON'T WANT TO TAKE IT TO THE DEALERSHIP!!!
I had similar symptoms. I thought it was the battery at first, but it turned out to be the RCM was bad even after the resolder. I have more than 1 XF so swapped out the RCMs and it solved the problem and moved the problems to the donor car. Amazon has aftermarket plug and play RCMs for $150 if you need one. always good to have a backup anyway.
