Re: Strange combo of symptoms
Wadsworth
Glad you found the problem with the battery. If you still encounter issues, you could swap RCMs between the 06 and 07 and see what happens. I am still running on original RCM but have a backup just in case. Failed RCM is a recurring topic here.
An advantage to having more than one XF is the ability to swap items. It took 5 minutes to swap the RCM from '07 coupe to the disabled '06. It started immediately and all symptoms gone. Seems it wasn't the battery after all but the RCM. Thank you Wadsworth for the advice.
