Old May 29, 2022 | 01:29 AM
MAYAman's Avatar
MAYAman
Default Re: Putting in my lighted door sills. Need help
That is the wire, black/yellow with white bands, the instructions make sense to me.
I used that wire, it did not function. I’ve achieved success by using the following.
the power wire needs to be extended behind the bulkhead carpet, then you tap and solder that power wire to the Red wire with gray stripe in the wiring bundle along the bulkhead on the drivers side.
the brown ground wires are connected as so. Passenger side tap and solder to the brown and pink wire in the passenger door switch. Extend the second brown ground wire to the drivers side and tap and solder to the brown and gray wire on the drivers door switch.
presto, working door sills. With this knowledge this is really at most a 2 hour job, if that. Do not follow the official instructions, they’re wrong. Also, my sills were labeled incorrectly at the factory lol. They had a left label on the passenger sill and vice versa. You can tell if they’re backwards because the exit hole for the wires has to be on the back of the sill, not the front.
so total **** job by the factory labeling and writing these directions. But got it done and everything is buttoned up. Mine are green to match the dashboard lighting. Blue never made sense. My phone camera created the streaks.
