Scott_lmtd
Thanks Pizza Guy. Was hoping to get away cheaper but its not to bad and does look like it reads ABS too.
Well, took for a quick spin and no speedometer movement. Will check fuses and relay. Thanks
Further confirmation, Pulled the fuses in the RCM box and all looked fine (15Amp). Any idea where the relay is that can re-seat?
What are options if the relay is good, is the traction control unit something that can be repaired?
Also, the ABS - BAS/ESP lights are on. I've seen that before, went off after pumping the brakes a few times since it was sitting. Didn't go off this time with a short run around the block. Ugg,wonder if this is all connected.
