Old Jun 6, 2022 | 11:43 AM
nickwe21.'s Avatar
nickwe21.
Default Re: Single Din head unit with screen on a budget
Originally Posted by Sussudio
Check this out. https://www.joyingauto.com/joying-an...5ghz-wifi.html. Joying has been the highest rated of the the Chinese Android units. I have their 9” unit with the Android 9 firmware, fit to the AOZ kit. Pretty tidy install. Might upgrade to their Android 10 unit or just go with an iPad install instead. We’ll see. Hope this helps.
This is not a flip out radio I assume right? Could you take a picture of your dash so I can see what button it covers up? Is it annoying when you can use certain functions anymore because the screen covers them? I guess with the flip out ones you could at least slide it in so as to access the controls of our dashboard.
Also, did this require the adapter harness and antenna adapter? Thanks for your help!
