Old Jun 7, 2022 | 12:43 PM
Dantheman204's Avatar
Dantheman204
Default Re: Crossfire Smog pump \ Secondary Air Filter
Originally Posted by tighed1
Most likely code P0410. Check the contacts on the air pump relay in the relay control module. Bet that they are BURNT! May have been your problem all along. If so the relay can be replaced for about a third of the cost of a new RCM.
There's also a blue check valve that can cause issues.
Thank you foe the response. This makes complete sense !! The garage said the similar. In ghosts response I neglected to mention that A. I am in the UK so the garage I use doesn't have the schematics for some American vehicles.
I also neglected to mention that both pumps work. What happened is that when the engine was turned off the secondary air pump stayed on !! Eventually flattening the battery. Hence bought another pump and it did the same so effectively what they wanted to know was where the module or relay for that pump was so I can replace it.
Thx
