Old Jun 13, 2022 | 01:06 PM
Ronman's Avatar
Ronman
Default Re: Oil Level Sensor
Originally Posted by DeKalb
2005 Limited Roadster N/A, this is my first Crossfire, I purchased it in August of 2021 ... I have an oil leak at the oil level sensor, the sensor works but it looks like I need to replace the O-ring ... I know this involves removing the oil pan ... I have searched this Forum and found helpful instructions to remove the pan and sensor
Where is a good place to purchase the O-ring and pan gasket ... is one brand preferred over another? Any help and/or direction is appreciated ... Thank you
I do not recommend changing the o-ring only, the sensor might fail in the near future and you will have to do the job all over again. There is no pan gasket, you have to use an oil resistant sealant on the lower pan. I recommend the Mercedes sealant and you will need probably 2 tubes of that.
