Old Jun 13, 2022 | 03:07 PM
onehundred80
Default Re: Oil Level Sensor
Originally Posted by Ronman
I do not recommend changing the o-ring only, the sensor might fail in the near future and you will have to do the job all over again. There is no pan gasket, you have to use an oil resistant sealant on the lower pan. I recommend the Mercedes sealant and you will need probably 2 tubes of that.
I see no reason to replace the sensor if it is working OK, why replace something which has historically fail rarely? An oil level sensor is an item that can be done without anyway. There is a dipstick after all.
That is my opinion anyway, why replace a perfectly working unit. The new one could be faulty from day one and fail next month as there is always that part that slips by inspection.
If it ain’t broke don’t fix it.
