Old Jun 13, 2022 | 06:28 PM
onehundred80
Default Re: Oil Level Sensor
Originally Posted by DeKalb
So if I understand you right I can totally remove the sensor and block off the hole it goes through ... and doing this will not cause any other problems or warning lights on the dash ... the only thing is I would need to check the oil level using the dipstick, which is how I do it anyway ... simply unplug the wires, remove the sensor, and block the hole ... sounds like a plan to me
I found an oil pan gasket at my local NAPA ... looking at the pan still on the car, it appears to have a gasket
Thank you for your help, it's appreciated
No, that is not what meant all, I said if it ain’t broke do not fix it just cure the leak.
