Oil Level Sensor
Jun 14, 2022 | 12:48 PM
permalink
Ronman
Mar 2004
779
96
Re: Oil Level Sensor
Quote:
DeKalb
Think I found my answer after more research ... the Oil Level Sensor is also a Temp sensor so it seems ... I'll replace the O-ring and trust that stops the small leak I have ... Thanks for the help
You cannot cheat the level sensor (B40) in your M112 engine.
The sensor in the oil sump is a complex piece of electronics that sends continuous data on a) oil level, b) oil temperature, c) oil quality, to the ME- SFI control unit (ECU).
The data on the 3 functions is processed and sent as a pulse-width modulated, square-wave signal to the ECU and then transmitted via CAN bus to the Instrument cluster."
Ronman
View Public Profile
Send a private message to Ronman
Find all posts by Ronman
