No704
Anybody have the capacity specs on this system?
I believe the freon capacity is listed in the forum's free downloadable service manual. Make sure you do a proper vacuum on the system to draw out ALL the moisture before injecting the freon. Best if you have a gauge set, so you don't overcharge (you can damage the system). IF not. do the replacement of the parts and bring it to an A/C guy to install the freon (the parts needed to properly install the freon is VERY EXPENSIVE) Good luck!
