Old Jul 3, 2022 | 05:27 PM
DTMenace's Avatar
DTMenace
Default Re: SRT-6 Pulley change
Originally Posted by Carl Pederson
Hello All,
I have an 05 SRT Roadster and am considering changing the blower pulley for more HP. Has anyone changed that blower pulley? If so give me the details as to how and what to do. There is a fellow on Ebay in Texas that sells a 64mm pulley with a flash drive and another panel to upgrade the tuning. Has anyone tried that? If so did it work? I'm open to any and all suggestions. Thanks a bunch for any thoughts or ideas.
Carl
Fresno, CA
Carl
If you decide to go with a reduced supercharger pulley, avoid the aluminum, since several in the past years had imploded and caused major damage. If you decide to go that route, buy a steel one.
I would go with an ASP brand crank pully (177 cm's vs. the stock 155 cm's), virtually no failure rate, with the same results.
Use the SEARCH button and type in supercharger pulley or aftermarket crank pulley, you should find several threads about the subject.
Dennis
DTMenace
