Thread: battery drain
Old Jul 17, 2022 | 06:24 PM
triplmmm's Avatar
triplmmm
Default Re: battery drain
Originally Posted by ZERACER
Did you remove the connection under the cowl in front of the windshield? What wires did you cut? If the alarm siren itself is still plugged in it will probably continue to short.
Thanks zero. I did remove cowl and cut the only wire leading to the alarm. Hopefully that works. I'll know soon enough.
