battery drain
Old Jul 17, 2022 | 01:28 PM
triplmmm's Avatar
Default battery drain
I've had a battery drain for 5-6 years. Never really bothered me because i seldom drive it. I have a quick disconnect for the terminal i use.. Well after 5-6 years of procrastination i disconnected ( aka- cut the wire ) to the alarm today. Hopefully that was the problem. I'll let you know in a week. I really don''t feel i need the alarm since I've lived without for soo long. Not sure why people bother replacing them??
Old Jul 17, 2022 | 04:51 PM
Default Re: battery drain
Did you remove the connection under the cowl in front of the windshield? What wires did you cut? If the alarm siren itself is still plugged in it will probably continue to short.
Old Jul 17, 2022 | 06:24 PM
triplmmm's Avatar
Thanks zero. I did remove cowl and cut the only wire leading to the alarm. Hopefully that works. I'll know soon enough.
Old Jul 17, 2022 | 06:46 PM
. There might be a big problem already! The siren has THREE wires going to it ORIGINALLY. Good luck.
Old Jul 17, 2022 | 07:14 PM
triplmmm's Avatar
Crap, I'll see what happens. I was just being lazy. 5 minute job taking wipers and cowl off so no big deal if I have to do it again. Thanks
Old Jul 18, 2022 | 11:36 AM
Just pull the plug and tape it.
Old Jul 21, 2022 | 01:52 PM
triplmmm's Avatar
Thanks for input all. Battery drain is gone. I can't believe I waited this long to do a 10 minute fix. Per the number of connections I believe where I cut the wire it was bundled and that took care of all the wires.
Old Jul 21, 2022 | 06:09 PM
Surprising you didn't blow a fuse as a minimum. Cutting three wires that include a ground and +12v DC usually results in a blown fuse. Also, the +12 volts could have fed back into the 'signal' wire and toasted something else. You got lucky this time... Good luck, onwards!
Astrofriend
Oct 27, 2022 02:17 PM
MichaelMurugan
Apr 9, 2022 10:49 AM
513crossfire
Jan 14, 2011 11:39 AM
Camperdude
Jan 4, 2011 01:37 PM
jay bondrock
Nov 24, 2008 03:14 PM
