Replacement battery causing car alarm to go off???
Old Jan 13, 2011 | 06:55 PM
513crossfire's Avatar
Default Replacement battery causing car alarm to go off???
Okay so I replaced the battery in my 04' Crossfire with a Mopar battery purchased from the Chryler dealer.... well let me say I attempted to replace it. After attaching the negative terminal the alarm immediately sounded and headlights began flashing. Also, there slight sparking on the post. Everything appears to be off (headlights, cabin lights, radio, ect.). Additionally, the battery had died after about a two week period of being parked in the garage because I don't attempt to drive it on ice. Any ideas on what it could be or what I can do? At this point I can't even get it to the dealer without being towed? I'll warn you though my car knowledge is pretty minimal! Thanks
Old Jan 13, 2011 | 07:02 PM
GDC-SRT's Avatar
Default Re: Replacement battery causing car alarm to go off???
If you had the car locked and the alarm armed when the original battery died, The car will go into alarm the moment it gets enough voltage from a new battery.
You should be able to silence it with the key fob.
Old Jan 13, 2011 | 09:46 PM
stryfox's Avatar
Make sure you have a full charge.
Old Jan 13, 2011 | 09:53 PM
dtinker's Avatar
Make sure it is hooked pos to pos, etc.
Dave
dtinker
Old Jan 13, 2011 | 10:00 PM
Slight sparking on the post is normal.
Old Jan 14, 2011 | 06:37 AM
green-ghost's Avatar
ditto, thats why when you jumpstart, they say to hook the dead battery's negative to a solid part of the motor for ground. It'll spark but not near the battery which sometimes gives/puts out gasses that aare flamable. You dont want a spark there
Old Jan 14, 2011 | 11:39 AM
If the lights are drawing power then it will spark. Even if the car was working correctly it would still spark as there are components that draw a small amount of current all the time.
So this as stated above is normal.
backinblack
Aug 11, 2015 09:41 PM
autumnmass
Jul 2, 2015 10:35 PM
TropiGal
Jun 25, 2015 08:45 AM
gobraves423
Jun 6, 2015 07:03 PM
Rwright2
Sep 18, 2003 04:55 PM
