Old Jul 19, 2022 | 09:59 PM
onehundred80
Default Re: hood opening problem
Originally Posted by aandre01
Thanks again for your reply.
I removed the left fender trim in the trunk to see the oil level in the expansion tank.
With the hood closed, the level is approximately 3 cm below the minimum level mark.
I think as you say, that the problem can come from this lack of oil.
I ordered PENTOSIN CHF 11S oil recommended by MOPAR and a syringe to fill the reservoir.
I'll let you know the result.
Thanks
Remember if you lose some fluid you have to find where it went, otherwise it will happen again.
