Old Aug 17, 2022 | 09:22 PM
pizzaguy
Default Re: Intermittent non starting 2005 Crossfire New Zealand right hand drive
Originally Posted by GraemeQ
Thanks if it faults again will check
It will, you can bet on it.
What I would do (and what most of us have done):
1) Order a new RCM, they are not expensive, Keep it in the trunk as a spare - they fail rather often.
2) Order two new Crank Sensors. Replace yours. Keep the other new one in the trunk - they fail rather often.
The source for the RCM is not critical, but where you source the Crank Sensor IS critical. I like GermanAutoSupply.com; many use FCPEuro.
DO NOT search "Crossfire", search "2003 Mercedes SLK320" and grab the BOSCH part only.
