Old Aug 23, 2022 | 01:05 PM
pizzaguy
Default Re: Running starting and running problems the car will start twice and run for 2 seco
Originally Posted by exparamedic
Thanks AMX1397.
I forgot the basics and how many problems the RCM can cause. It should be looked at first.
Jim is the nicest, best guy on the forum, but I disagree.
The SKREEM is powered from pin 3 of the ignition switch, not the RCM. IF you are getting three cranks then nothing, the RCM is powering up the ECU, therefore, the RCM is not the issue.
One of the following is your problem:
1) You changed key fobs and forgot to transplant the little black RFID chip to the new fob. (You'd know if it you did.)
2) You messed with the dash and either damaged the black ring around the key or accidentally yanked the wires from the ring to the SKREEM out of the SKREEM. (You'd know it if you did.)
3) Your SKREEM has failed. (OFTEN happens.)
4) Your ECU has failed. (NEVER happens.)
