Thread: RCM Info
Old Sep 25, 2022 | 09:52 PM
tighed1's Avatar
tighed1
Default Re: RCM Info
Originally Posted by joeyav
Hello,
I bought a back up RCM on Amazon for $118.00 RY1562 (JD192Z-12V) Standard Brand
I later found out it was a knock off. It does have good reviews, so i gave it a shot.
Has anyone had good luck with this model or should I return it for a OEM unit?
I'm considering having the original rebuilt as Preventive Maintenance.
Thank you in advance for any feedback, love the forum.
Joe
FYI!
I DO NOT RECOMMEND USING THIS PARTICULAR RCM!!!
CHEAP COPY!!! Relays are CHEAP! Pins are smaller diameter and DO NOT make good connection to the car's connectors.
I can replace the relays but can't do anything about the smaller pins. If you have this RCM I would slightly bend the pins so that they make better contact in the car's connectors.
You've been warned!
