Old Sep 26, 2022 | 06:59 PM
  #1169 (permalink)
Deepsea21's Avatar
Deepsea21
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Originally Posted by BrushRoadster!
Anyway, I wanted to heartily thank EVERYONE who contributed to building this thread, and for the useful information it contains! It is an absolutely awesome reference, and the level of detail, instructions, and pics is wonderful! Thank you ALL!
Now, open the fuse panel on the left side of the dash that you can access with the driver's door open and on the inside of that plastic fuse cover write "Sticky Key" which seems to be where many make a note of having made this mod. so any future owner will know it has already been performed (if that owner ever has a problem and cares to research such things). The Sticky Key fix is a necessity on these cars because it is not a matter of "if" but "when". A dealer or many repair shops will charge a fortune and replace the ignition with a new one that has the same problem and will fail just the same in time.
