pizzaguy
YOu have got to give us more than "right side of car". Is it from outside the cabin? Is it from in the cabin? Is the car a Roadster or Coupe?
How many things can it be?
Brakes (wear indicators are making noise or brake slides may need some grease)?
Wheel bearings? (Can be intermittent)
Worn bushings? (This would be really noticeable over rough road)
Shaft bearing? (This would be pretty constant)
Roadster or Coupe, the noise should be the same
My money is on a worn wheel bearing
