Old Oct 4, 2022 | 07:00 PM
pizzaguy
Default Re: Diagnostic Socket fuse blows
You better keep looking in the service manual, the steering angle sensor is in the steering column, but it's before the clock spring.
I'd be quicker to suspect a bent pin in the diagnostic connector to be the culprit. If we can trust the manual's diagrams to be accurate, (and we can't), then you have limited suspects here: The diagnostic connector, the steering sensor or a wire somewhere pinched to ground.
