Old Oct 12, 2022 | 11:14 AM
GraphiteGhost
Default Re: door and trunk not locking with fob
Originally Posted by Denny White
Yes, fuel door does lock??? I pulled off the right side trunk panel and saw where one of the air lines split thinking it went to fuel door or trunk.
No matter where the line goes, fix it and you'll probably have working 'everything' locked/unlocked again. There is a threshold whereas if there is a leak somewhere, the system is trying to work, but lack of a sealed system will result in strange behavior (depending on where and how bad the leak is). There are some posts on how to fix specific areas of leaking air lines, just use good common sense and you should be fine. Good luck!
