Old Oct 12, 2022 | 11:26 AM
GraphiteGhost
Default Re: Skreem going bad?
Originally Posted by WonderMellon
I did not replace fuse 9, but I did check it. It is working. Once I went through the process of disconnecting the battery, pulling the fuse, reconnecting the battery, retraining the fob, and replacing the fuse; everything seems to be working just fine. I am just worried about the cause and if it happens again when I am not in my driveway.
As advised, check the lower hatch area right side for the module in there, for water. If there is water in it or has signs of water being in there, fix whatever is damaged. IF the module is damaged, also replace a portion of the wiring for that module since the water would have wicked up the connectors/wiring and will probably fail eventually. Check first, then follow up with what you find. Good luck!
