Old Oct 20, 2022 | 12:27 AM
pizzaguy
Default Re: P0400 Help Needed
B+ is the feed from the battery thru the Engine Control relay on the RCM. You will have battery voltage anytime the key is "ON". And yes, the PCM pulls pin7/1 to ground to activate the EGR valve; that is, to open the valve and allow exhaust gas to pass thru to the intake.
