Old Oct 24, 2022 | 03:07 PM
pizzaguy
Default Re: What battery 2022
Originally Posted by Jack G
Maybe a general alternative for those who do not drive their xfire's somewhat regularly and only used them in the warmer months is to install a HD disconnect switch as I have indicated in my post #13. Doing this would allow considering a lower cost battery to be used. I do not recommend using the on-off screw type disconnect that attaches to the battery post. The recommended HD switch will make long term storage very simple and safe. As an option, a battery tender can still be used to help keep the battery at peak power.
I see a real problem with that advice: people will buy the first $4.99 item they find. Such cheap crap will disconnect or go resistive while the engine is running -taking the battery out of the circuit, endangering some very expensive modules.
The battery is your secondary voltage regulator and "brute force filter", operating the car without it is dangerous. A TRUE heavy switch is fine, EMS and some Fire vehicles have them.
