As fresh as the adhesive is a heat gun may allow you to pull the fabric loose in that area. I would sure try that before giving up on the fabric install.
Sounds like a good idea and I'll give the heat gun a try on the fresh glue. Already ripped the fabric off and scraped the foam off with Acetone. Glued the two front corners back together.
Update: Just tried the heat gun and it does work except gets pretty hot on the hands when rolling off the glue. Gonna buy some lacquer thinner and see how that works.
