Old Oct 26, 2022 | 12:43 PM
onehundred80
Default Re: Headliner fun has begun! (Sort of!)
Originally Posted by Romad
The Acetone worked a lot better than the Lacquer Thinner. I tried the heat gun once again and got a blister on both thumbs from trying to heat and roll the adhesive. Think I'll go back and buy another can of Acetone. I decided to use Rust-O-Leum tested paint instead of the truck bed liner. It's a light sandy texted feel and will use a primer underneath and clear coat over the paint. (Should I ever get this adhesive removed!)
Put on at least two coats of undercoat as that board will suck up the first coat and leaves blotchy finish coat.
See how two coats of undercoat looks, if it is blotchy put on another coat. The same goes for the final coat.
You can buy size which seals the surface, two coats of that and one coat of undercoat should be enough.
You buy size in the paint department it is thinner than paint and sinks in well.
Whatever you use check the product by doing a little area first, I would suggest the area that gets hidden by the trunk roof liner.
