Old Nov 2, 2022 | 05:48 PM
pizzaguy
Default Re: Rear window latch not opening
Originally Posted by skarlet
So how do I check the fluid from what i have seen in the posts you need to get the top to move to get at the fluid reservoir. if I am wrong sorry, can i get to it without moving the roof. I do not have the special tool, we bought it used.
thanks
ZERACER is right, but you can also access the pump/tank by removing trim from the trunk area.
You must hit the button to put hte top UP, even tho it is up, if the trunk lock is still locked. Pressing "UP" should unlock the trunk lock so you can get in there.
