Old Dec 5, 2022 | 08:37 PM
pizzaguy
Default Re: Rear spoiler behavior & battery drain
Originally Posted by matchbox_greg
The battery shop in Cincinnati swapped the current battery for a brand-new one. I put the new battery in and conducted your "Battery Drain" test. It went exactly as you described. Initially it showed a current just short of 0.3 amps. After settling into hibernation, the current jumped between 0.01 and 0.02 amps. So, I guess that's normal, right?
It is lower than average which is good. Mine runs just below .02 amp.
That red light is still illuminated in a solid fashion on the spoiler override button on the console. Is that normal?
No it is not.
I"d start the engine and measure battery voltage right across the battery (make sure you change the leads to the right jacks first).
The battery voltage should be 13.80-14.20 with the engine idling and up to 14.4 at 2000 rpm.
