Old Dec 17, 2022 | 04:35 PM
dinasrt's Avatar
dinasrt
Default Re: Supercharger does, sometimes, not kick in
Originally Posted by hanvanputten
Ok, I’ll replace the pump. On the temperature: obviously I meant it is always around 30 degrees Celsius, like between 28 and 32. To me that means the pump is working?
I’ll be back.
Han
How are you monitoring your coolant temp.? What are you reading it with? IMHO, when you removed and replaced your charge air intercooler, the pump should have been checked and or replaced at that time also. Where did you get that CAC replacement? Good luck; let us know if the new pump fixes your issue.
