Old Jan 7, 2023 | 09:55 AM
Romad's Avatar
Romad
Default Re: SKREEM Conumdrum!
Last couple of days it has started every time. As mentioned I already installed a "new" RCM. Went for a drive this morning and all is still good for starting. When I parked at home "NOW" I have the stuck key problem and the key is stuck in the ignition. The key starts turns fine and starts the car but won't come out of the switch! The steering wheel does not lock either when is the off position. Hope I can get at that little trap door and remove the spring and pin to let the key come out. (If that has anything to do with the problem.) While doing that I'll install the new seat relay.
Second thoughts might it be a tumbler problem instead????
