Old Jan 7, 2023 | 07:08 PM
Romad's Avatar
Romad
Default Re: SKREEM Conumdrum!
With the key stuck in the switch I could not manage to remove the assembly as the key was hitting the bezel. Anyway I'll leave the bezel off for now because I will remove the SKREEM module should I have no start problems in the short term. I'm pretty sure I can paste the bezel back together and not be too noticeable. Two of the attachment lugs are broken as well as a 3" piece on the backside. I only want to reinstall it back "once" should I have the SKREEM repaired.
Another side note: While the bezel is off I want to investigate my idea of installing a small led light on it to illuminate the dark LED gages. As is now I have to use my parking lights on during the day to be able to read them. It would be on all the time the ignition in in the on position.
