pizzaguy
1) This sounds like you have two wires reversed. There is an ignition power lead and a battery power lead. If you reverse them, you have no battery powerred memory backup. Most VW harnesses have these wires backwards for some reason (or so it seems, as I hear of this complaint a lot).
2) Again, some harnesses leave out the enable line from your new radio to the audio amplifier below the passenger's feet. If the amp is not enabled, you get no sound.
You may need to get past this idea that this will be "plug and play". There are threads here that speak to these issues and show you how to modify the harness for the connections you need. I am in the middle of a lot of stress and personal trouble, when the load lifts, maybe I can help. Until then, please look over threads in this part of the forum.
You might be right completely- so I done some digging
