Re: 2007 Low mileage Limited Coupe to do list?
Anther item that needs maintenance would be the plate where your rear spoiler attaches to the car. I believe all will leak eventually, so repair it before you get into deep trouble with a failed vacuum pump. There are several other areas where a leak can occur but this is the primary problem area. Remove the plate clean the area and reseal it with "Mortite" weatherstrip caulking cord.
You can use the search box in the upper right corner of this website for more info. Type in leaking wing and use the google option by hovering your mouse over the threads option directly to the left of the search box to get the best results.
