Re: Catalytic Converter repair problem.
NeedsWings
take the pipe off the car, clean up the cracked area as best you can, wire wheel and then acetone. then bring it to a local TIG welding shop and have them weld over the crack
I'll do just that as suggested. I'll remove it at the exhaust manifold flange and cut somewhere before the exhaust pipe so it can be rejoined with a coupler. It will probably be next week when I can get to it.
