Old Jan 23, 2023 | 11:47 AM
Mark Hampton's Avatar
Mark Hampton
Default Re: Made a holder for my phone
Originally Posted by Americium
I’m attempting to attach a couple files of the phone dock, hopefully it works.
One is the .3MF gcode file that my 3D printer reads, the other is a .STL file that most solid modeling programs should be able to import. Then you can modify it to fit your particular phone. As I mentioned earlier, this model is made to fit an iPhone X with a Quadlock case. No guarantees that this will work for you, I’m providing this as an experimental item to give a starting point to make your own Dock. In downloading and using this model you agree that I am not responsible or liable for anything regarding the manufacture or use of this phone dock. Use at your own risk.
Having said that, it’s just a phone dock and if you need such a thing it will be helpful to keep your phone in one place. Enjoy
edit: I uploaded the files but they seem to have disappeared. I see that they are not on the list of valid file extensions. Does anyone have any advice on how to get these files posted here?
edit: tried again and the 3MF file was rejected as invalid file type. The STL file remained but disappeared upon saving the edit.
Try Thingiverse to upload it and then make a link to it.
I will need to make it fit my Pixel 6 if I plan on using it.
