re: Help with Sticky Key Lockup
Are you referring to the sticky ignition? If so, no drilling needed. Remove the ignition switch and If I recall correctly there's a metal cover over a spring. Remove the cover and the spring. No need to replace the cover. Remove the spring and you should be good. I did that in 2005 on my crossfire that now has 500,000 miles.
