Help with Sticky Key Lockup
Old Jan 23, 2023 | 12:09 PM
Forest46's Avatar
Default Help with Sticky Key Lockup
Hi all, long time member but have not posted in a few years and couldn't remember my login details. Basically, I have owned my coupe for almost 12 years, and it's been really reliable up until 2 months ago! Yep, the dreaded ignition failure, and it's been a nightmare! Nobody will touch it here in the UK, so I am trying to fix this myself. Having to drill out the barrel because the little pin thing won't push in and I have watched the video via this site, which has helped massively! So, I just wanted to say hi really and any tips would be gratefully appreciated. 😊
Old Jan 26, 2023 | 07:25 AM
liljay's Avatar
Default re: Help with Sticky Key Lockup
Are you referring to the sticky ignition? If so, no drilling needed. Remove the ignition switch and If I recall correctly there's a metal cover over a spring. Remove the cover and the spring. No need to replace the cover. Remove the spring and you should be good. I did that in 2005 on my crossfire that now has 500,000 miles.
Old Jan 26, 2023 | 09:39 AM
Read the post again. His locked up and he's drilling the pin out.
Old Jan 26, 2023 | 09:41 AM
Default Re: Coupe woes.
In the "Sticky Key" thread there are posts from people who have had to drill out the pin, lots of advice in there.
There really is no short-cut once it locks up like that, tho. You will get there, just takes time and effort. And it helps if you are nimble, thin and young - which most of us aren't.
EDITED TITLE because generic thread titles help no one and make the search function ineffective
hoppercp
Aug 19, 2018 03:04 PM
ggwersal
20
Feb 26, 2014 09:59 PM
Uzi
Apr 26, 2011 07:40 PM
tpoag
Aug 21, 2008 08:37 PM
Cyril Baldwin
May 7, 2004 05:58 AM
