Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
Awesome, thanks man ! Yeah I got confused by the "If the key won't turn, skip to Key Won't Turn, then go back to step 17"...it finally came to me, that the very last page was "Key Won't Turn", but it's not really labeled as such. Thanks for clarifying !
The other part that confused me was "grinding the pin down" does that actually work ? Seems like if it needs to be pushed in, grinding it flat wouldn't accomplish anything ? I guess from that point of view drilling it out would have the same conclusion. I assume there is some type of a mechanism inside that requires being released. I'm trying to comprehend how it works haha.
Either way, thanks for the help !
EDIT: Oh yeah, that version of the PDF I haven't even seen..doh ! I see why the grinding and not the drilling. It just needs to make it past the clampppp. Ok. This version is written wayyyyy better. I appreciate you pointing me towards this !
