Acellerator Woez
'04 coupe. Getting a P0122 and have all of the instructions for removing pedal and checking out on the bench. Got the plastic cover off and there endeth the ease.
Get 10 mm socket on nut. Is hard to turn but does. And turns and turns and turns but does not come loose. Soaking with PB Blaster but looks shiny. I suspect the stud has come loose and is just spinning.
OK so how do I get to the other end ? Seems to be under the floorboards but are all sort of things in the way. Is there a trick ? Suggestions welcome.
Am getting suspicious that PO worked onnit with a crowbar.
