Old Feb 2, 2023 | 01:26 PM
nicolas-e63's Avatar
nicolas-e63
Default Not start, no rotation of the engine SOLVED
Hello every body
As writen in my presentation :
I 'm french, so my english was not very good
I buy a lovely Crossfire who won't start.
Before going a head with my problem, I want to confirm I'm not a professional, don't want to do money easy, and I'm the owner of the car (buying 2 weeks ago - paper could be show at at admin of this site)
To come back to the car :
Last professionnal owner have lose the only key.
They have send the ECU to carlabimmo to unlock key with emulator :
I will consider that they do their Job good.
Ignition barel have been change (no electronic inside key).
As ask by carlacb, Skreem unplugged.
What happens :
When I want to start, no thing, and after few second, cooling fan go to max speed.
For me, if skreem, electronic key problem, the crank must go, engine start
sec stop, and could do nothing after 3 tests.
In my case, cranks not go.
I will control, pumpe pump seems to go one few second.
I controle all the K40 box, all contact and all inside component = OK.
My first goal will be to test crank starter. Do you know where the relay is located ? Not seems to be inside K40 relay box ?
Thanks in advance to have read me ... and help will be friendly
Regards
Nicolas
