Old Feb 5, 2023 | 03:18 PM
zip439's Avatar
zip439
Default Re: Not start, no cranck
nicolas-e63. This may help you. The Pulse Module has two relays in it . One of which sends the start power to the starter. It is located in the fuse box on the opposite side of the car from the RCM and it is under the black plastic that holds the fuses. You must pry the top of the fuses up to see the pulse module. Click here for more info; Pulse Module
