Re: Low brake pad light
Your pads might be ready for replacement. There's a sensor inside one of the pads on each wheel. If the sensor which is a wire comes in contact with the rotor the sensing circuit (simple continuity) indicates it's time to replace your pads. This is just a warning and will not cause anything drastic to occur with your braking system.
