Low brake pad light
Old Feb 6, 2023 | 03:15 PM
slyfox1812's Avatar
Default Low brake pad light
Hello. Yesterday the dash light for low brake pads had come on, it stays on until I push the pedal. I checked the fluid level, and the pad thickness. The brake fluid is ful, and the pads are in good condition. Could the sensor be going bad, and how would I test
Old Feb 6, 2023 | 10:01 PM
Jack G's Avatar
Default Re: Low brake pad light
Your pads might be ready for replacement. There's a sensor inside one of the pads on each wheel. If the sensor which is a wire comes in contact with the rotor the sensing circuit (simple continuity) indicates it's time to replace your pads. This is just a warning and will not cause anything drastic to occur with your braking system.
kstewart
Mar 27, 2016 08:33 PM
N8346T
Aug 27, 2013 07:34 AM
soulintent
Mar 20, 2013 03:15 PM
autumnmass
Nov 19, 2010 12:53 PM
beeblebrox
U.K.
Sep 2, 2008 08:50 AM
