Old Feb 7, 2023 | 01:17 PM
WD40's Avatar
WD40
Default Re: 'Hoovies Garage' bought a $1,900 Mercedes-Benz SLK32 AMG
Originally Posted by Padgett
Was on Motor Trend last night (Maserati). Used to reverse the diodes and put Delco alternators on Jaguars. Also adapted CS120 and CS144s to several more modern cars (BMW Turbo Diesel). Of course the modern GM seems to use mainly Denso. Seems like I put a 10SI on a FIAT 124 Spyder but was in the 70s and my memory....
I understand. All GM/Delco. All reliable alternators. I force-fit a CS130 to the Maser IIRC. In Jacksonville I took alternators to the actual rebuilder/used-alternator supplier to Pep Boys, etc. and had him install the best components possible. After that connection went away I've only bought BRAND NEW alts since then, as I had several bad experiences with rebuilds.
