Thread: Convertible Top
Old Feb 11, 2023 | 10:48 PM
pizzaguy
Default Re: Convertible Top
I checked all my previous work this evening my # 11 line is on top the 12 bottom .
You have a gift for not being clear. I wonder what that means. I am not interested in taking the time to guess that you mean a fuse, a hydraulic line, or something else.
I cycled the top manually a half dozen times and then brought the reservoir up to full. I got in the car started it up and the switch was still blinking. I shut the car off and had this brilliant idea to pull the fuse in hopes of resetting everything. I had left the key in the on position with car not running and pulled the fuse. I heard some clicking under the hood and now ...the car wont start ! Oh Lord now what ? Don't know if the top goes up or down ,but at this point I really don't care. ..HELP !
You have a gift for not being clear. (Did I already say that?)
WHAT fuse? If you pull a fuse that takes power from the ECU, once you put the fuse back in, the throttle body will go thru it's startup sequence, which is a bit noisy and normal.
And when you say "Won't start", what do you mean? Does the starter engage and spin the engine or not?
PLEASE CLICK THE LINK IN MY SIGLINE BELOW.
