Re: tire sizes to fit your car
the height and width of the tire is what matters, stay close to the 26"tall ,,if the tire is wider then reduce the offset to 30 so the wheel goes into the wheel well so it does not rub., and you don't hit the rotors.
years ago i ran a drag radial 315/35-17 = 12.4 wide,, 4.3 rim to ground and 25.7 tall they spun too much ,, any thing smaller than 26" tall will spin,,, anything taller than 285/35-19 ,, 26.9 will rub in fact this tire will rub in fast corners and at high speed
26.6 is the tallest tire i would use stock rim that would be 275/35-19
\stock 255/35-19 you can use with stock rims
265/35-19 or 275/35-19
(255/30-20 recommended by factory),,205/25-20 ( 12" wide)
265/30-20
and on the front 225/30-20,,,225/35-19 235/35-19
AND HISTORY REPEATS IT'S SELF I POSTED THIS IN 2011
