Old Feb 17, 2023 | 07:53 AM
  #57 (permalink)
dedwards0323
Default Re: How do I Jack up my XFire with a FLOOR JACK???
Originally Posted by MountainGoat
Coming back to the original question: has anyone fabricated the white nylon end from the Crossfire jack onto a hydraulic floor jack?
There are lots of M-B Jack Pads available that can be used with a Hydraulic Floor Jack. I've probably got a dozen or so, both aluminum & rubber, in my garage cabinet that I've used. I typically use smaller 2-3 ton Floor Jacks just because the lifting pad is smaller which makes it easier to position under the Crossfire's lifting point with a Jack Pad Adapter.
But if you're asking about one that works with a Hydraulic Bottle Jack, hardly any are available. However, looks to me that you could use a low profile M-B Jack Pad (metal versions are typically a lower overall height than the rubber versions) that would fit into the car jacking points. Then if you use a Bottle Jack Pad Adapter mounted to the jack's shaft, you could position this under the M-B Jack Pad & lift the car. Bottle Jack would have to be a stubby or low profile version as there isn't much space under the Crossfire rocker panel. I looked around last night for a M-B Jack Pad designed for a bottle jack but never was able to locate one.
CLICK"><span style=CLICK" /> CLICK">CLICK
